I would not expect any problems. The 215's will be a bit larger diameter as well as a bit wider, but it's not a big difference and I doubt clearance is so tight that it would cause problems.
If you are going to be using a higher pressure in the tires, it would be wise to double check what pressure your wheels are rated for.
