PerryB67 wrote:
Rich Solar makes a 200 watt 24 volt solar panel.
I would remove my rear mounted 170 watt 12 v panel and purchase two of these Rich Solar 200 watt panels, with room to add a third if needed. One would be on the front and one on the rear of the camper. The 200 watt can be mounted in the same mounts as the existing 170 watt. I want to run parallel since we will be traveling where shade is often on either the front or rear of the camper.
I have a Victron 100/30 smart controller already for this setup.
Smart move or a waste of money?
Enjoy,
Perry
What does your battery bank look like? (how many AH?)
What about just adding another 170w panel? Would 340w deliver what you need? (If so, it saves you $200+). Or do you really need 400w (or more)? If you only have 200-250AH of batteries then 340w will likely be enough for most of the time (unless you are camping in shady areas or in bad weather). Do you have a backup generator just in case you need it?
OR, for likely less money you could buy TWO more 170w panels and then you'd have 3 panels delivering 510w for less price than buying two 200w panels (400w total) and having no use for the existing 170w panel. (I'm assuming the similar 170w panels are a little cheaper than the 200w version).
-Chris
