PerryB67 wrote:
Rich Solar makes a 200 watt 24 volt solar panel.
I would remove my rear mounted 170 watt 12 v panel and purchase two of these Rich Solar 200 watt panels, with room to add a third if needed. One would be on the front and one on the rear of the camper. The 200 watt can be mounted in the same mounts as the existing 170 watt. I want to run parallel since we will be traveling where shade is often on either the front or rear of the camper.
I have a Victron 100/30 smart controller already for this setup.
Smart move or a waste of money?
Enjoy,
Perry
Or search your local craigslist or facebook or nextdoor for something like these...
https://minneapolis.craigslist.org/ram/grd/d/carlton-310-watt-solar-panels-105-each/7301662326.html
300w for $120. 600w for just $240. Not sure you need 600w, but just an idea...
I was going to just put up a 250w system with a used panel on my RV. When I went to pick up the panel, they were on sale for $35 each (this is from a big used solar company in Arizona). To me, that's pretty much free. So even though I didn't need it, I put up two panels for 500w total. I've boondocked several times now and they work great. I'm adding a 3rd lead acid battery making my bank 300AH. It's more than I need and the solar easily keeps everything charged. It's nice never worrying about having enough power....
Good luck!
Chris
