PerryB67 wrote:
Rich Solar makes a 200 watt 24 volt solar panel.
I would remove my rear mounted 170 watt 12 v panel and purchase two of these Rich Solar 200 watt panels, with room to add a third if needed. One would be on the front and one on the rear of the camper. The 200 watt can be mounted in the same mounts as the existing 170 watt. I want to run parallel since we will be traveling where shade is often on either the front or rear of the camper.
I have a Victron 100/30 smart controller already for this setup.
Smart move or a waste of money?
Enjoy,
Perry
30 watts for an upgrade almost seems like a waist of effort these days with the price of solar panels. look at split cell 24V panels and I would go 325 or 350watts.
I am running one 325 watt 24V split cell on my camper with a renogy MPPT controler and it out preforms the three 160 watt 12V pannels on a PWM in my 5th wheel, so thoes will be gerring switched out soon.
if you can chage it out for one 325 or 350 watt then add a second one. then you only running two panels which most people should have room for.
Steve
