PerryB67 wrote:
StirCrazy wrote:
30 watts for an upgrade almost seems like a waist of effort these days with the price of solar panels. look at split cell 24V panels and I would go 325 or 350watts.
I am running one 325 watt 24V split cell on my camper with a renogy MPPT controler and it out preforms the three 160 watt 12V pannels on a PWM in my 5th wheel, so thoes will be gerring switched out soon.
if you can chage it out for one 325 or 350 watt then add a second one. then you only running two panels which most people should have room for.
Steve
Ah........ I would be removing the single 170 watt panel and installing two (or three) 200 watt 24v panels. That was clearly stated in my original post you just quoted, and would be an increase of 230 watts with two panels or 430 watts with three panels.
Enjoy,
Perry
no thats what I mean though, if you can fit two or three pannels on there why stop at a 200 watt? a 350 isnt much bigger and two of them would be better than three 200watt panels then if you need a third you can add it later. down in the staits whats the difference between a 200 and 325 -350 down there 30 bucks? its only about 50 bucks up here. bang for your buck it just seams a better option.
Steve
