SCVJeff
Aug 08, 2013Explorer
MCIbus wrote:As I said, they are all on remote places so I can't go look, but I think they came with a 20A cross plug for that reason. All I can tell you is that more than one system is on a 15A breaker and I am aware of two complete recharge cycles where the breakers held. The engineering guys are in Tucson, so you might call them and see if there is a pot in there that you can turn back. Just be aware that they are reluctant to divest info like that unless they are convinced you either know what you are doing or have a spare bottle of smoke close by. I just told em I had a tweaker and will start turning things if they didn't start talking fast.. :)
Thanks.
We tested the converter on a set of batteries that were at 25 volts and my tiny genset was able to run it just fine. Now owners of a IOTA DLS-27-25 converter.
SCVJeff
I know they make a 40a 24 volt, but it has a max ac input of 19.9 ac/amps. A 15 amp breaker should be able to handle 12.2 amps continuous and would not handle 19.9 amps for long. If I was on a 12v system than a 40 amp would be great.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
