tpi
Mar 14, 2015Explorer
At least from my limited knowledge, the 24 volt panels work for my friend on his bus.
1. The physical size works for him. Works with what is already on the roof.
2. Running at a higher voltage it appears from the controller documentation that the wiring sizes can be smaller. Wiring from panels to controller-which translates voltage to what is appropriate to batteries.
3. Cheaper per watt.
Thanks for the input. Ordered the panels.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
