BFL13
Mar 14, 2015Explorer II
This summer I intend to run a test of my 24v panel with MPPT to the 12v battery bank, vs the same panel with PWM on the same batteries wired as 24v.
I am suspecting the summer heat on the panel reduces the power enough to put the PWM on 24v ahead in amps to the battery.
Even if the 24v PWM comes out ahead, the problem remains to get 12v to the trailer. Anyway first to see if it is better, then see if it is "worth" solving the 24 to 12 problem.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
