westend
Mar 14, 2015Explorer
tpi wrote:Edited my above post. The 22 amp current limit is INPUT. As 2oldman said, a bigger controller won't be tossing away charge current but I'd doubt there will be much to toss with two modules.
Westend, what you're saying is it is essentially OK to let the controller limit the output to the 22 amps? There was nothing in the documentation that sounded too dire if you were to exceed the recommended input.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
