BFL13
Mar 14, 2015Explorer II
Nit-pick, the wiring for a 24v panel set-up to 12v battery is only different for the panel to controller section (can be thinner with 24v). The section from controller to battery is 12v, so it is the same gauge. If the batts were also 24v, then the wiring on that section could be thinner too.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
