Ed_Gee
Mar 15, 2015Explorer II
tpi wrote:
Is this panel decent? Or is there reason to buy one of the slightly more expensive panels from Solar Blvd? Friend has Blue Sky controller capable of using the 24 volt panels.
https://www.solarblvd.com/product_info.php?cPath=1_270&products_id=3005
IF you are going to use a MPPT type charge controller, this will be a good panel for you as the MPPT charge controller can make good use of the excess voltage this panel can put out.
IF you don't use an MPPT charge controller, then you are wasting money and should get the 12V type panels with the nominal 17 - 22 Volt DC output.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
