Almot
Mar 16, 2015Explorer III
tpi wrote:
This is the plan I'm thinking-
1. Have panels switched between panel and controller, so on June 21 midday (or similar seasonal) in clear weather one of the panels can be switched off if there is chance of exceeding controller capability. When in storage-just operate on one panel for maintenance.
2. On an as needed basis, when present in the RV maybe he can push the envelope a bit with the controller and let it limit to the 22 amps..in the event he needs the power. If something starts to smell hot, feel hot etc. he can shut off a panel. Depends on his comfort level with that.
3. Living in CA he does a lot of camping fall winter or spring where all capacity could be used. Mornings and afternoons in the summer too. Overall he should get good bang for buck on the panel installation. And he's open to another controller in the event of it being too restrictive.
1) and 2)
In theory - yes. You can test the install on the best day and estimate whether you will exceed the limit. In practice - despite that estimate, you might still exceed the limit on a cold clear day, and when you smell something burning, it can be too late. My 2*245 flat install does exceed 20A at times in the "neighboring state" of Baja California in winter at sea level. I have 30A MPPT, and the manual suggests max array 430W (I have 490W), but they are not too stern about dangers of exceeding the limit.
With your 20A controller it all boils down to how well this particular model takes the heat - the more amps, the more heat in the circuit. Plus, high amps are often accompanied by high ambient temps in summer. Panel output decreases when ambient rises, but there is A LOT more sun radiation on the flat panel in summer, so in the end, in summer you'll get more amps AND more heat.
Yes, in storage I switch one panel off. This involves climbing the roof, which is not something too enjoyable, so I'll probably stop doing it because chances of exceeding my 30A limit in storage are zero due to batteries in storage being Full all the time. When it's Full, there is no current. But you plan on climbing the roof suddenly when you smell something burning, and when you're are in a hurry, bad things happen. Better get a 40-45A controller for that 500W array.
3) Yes, there are 20A MPPT Chinese clones that can be had for $100, I won't comment on their features, but adding another 20A controller is too much pain. You would need to run another set of wires, and install another breaker, and to find a room for that another controller. There is usually very limited room in trailer. It's better to get a 40-45A controller instead.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
