MEXICOWANDERER
Sep 24, 2018Explorer
I need "someone" that can accept an email image of a drawing then post it. For whatever reason I have nothing but problems accessing a photo image site then trying to use it as an image base for url based images.
Basically all three meters need tiny wire. Even 25 gauge would do fine but the fat limit would be 22 gauge. Simply strip the end of the wire and stick it into the recessed clamp then tighten the recessed screw (it's recessed for safety)
Each screw terminal can accept 2 wires. So it's Christmas lights series with one black wire for phase and one white wire for neutral. Each module has four wires except the last in line. Being AC polarity is not important.
The frequency meter inductive pickup wires length is too short. Period. It needs to be extended and the extension would require soldering on an extension. If used correctly tiny butt connectors for 22 gauge wire would work if they ended up solidly crimped.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
