CA_Traveler
Feb 17, 2014Explorer III
bigdogger wrote:And I got 240V on a 30A correctly wired 30A plug. :hTin Pusher wrote:Since the recepticals at an RV park are used by RVs daily it would be virtually impossible to have a 30 amp one deliver 240 volts and not have been noticed before you arrived. Since the proper wiring would have been run to that outlet, it would be nearly impossible to even miss-wire a repair because only one hot wire would have been run to that outlet. A mistake leading to 240 volts at a park would almost assuredly be a miswired repair to a 50 amp outlet. That mistake would be reversing a hot with the neutral.
At every CG, before I plug in, I take the VOM and check it. Had a friend who got 240 at a CG (don't know where).
Doesn't seem very likely, but once is too many times :)
The problem was a bad neutral in the 240V CG distribution system. My PI HW50C shut down the rig power and was displaying 160V as ran out to remove the plug.
Very high voltage can and does happen on a 30A RV plug.
