Tin_Pusher
Feb 18, 2014Explorer II
pcmentor29, Well, if the ground is open, you get one yellow light in the center.
If the neutral is open, you get one yellow on the right.
If the hot is open, you get no lights.
If the hot and ground are reversed, you get one red light, one yellow on the right, and so forth per the LABEL.
