time2roll
Aug 23, 2016Nomad
joebedford wrote:How about post your local fuel and electric rates.
I'm toying with the idea of getting an electric car. However, electricity in Ontario is so expensive I suspect electric is more expensive than gasoline.
Depending on the vehicle and driving style you should get about 4 miles per kWh.
Does the utility allow net metering? Is there any TOU (time of use) rate schedules available?
Have you talked to a solar installer? You should.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
