stacaz822
Dec 11, 2017Explorer
At first I tried a 25K resistor, then 100K, and then 250K. They all worked the same (basic small 1/4 watt resistors), dropping the voltage down from 80, to 70, to 68. And when you apply the math, you end up with only 0.02 watts through the resistor, AND the hour meter. I just wonder why the meter still operates on such small wattage...My goal was to get the AC voltage down to 25 or so, based on the specs for the meter. Apparently, it works otherwise...and at 0.02 watts, it will *never* get hot.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
