rtaylor0830's avatar
rtaylor0830
Generator hour meter not working
I bought a new 2016 keystone carbon 357 it was generator prepped and I had the dealer add a generator when I bough it. I used the generator for the first time for two hours but it did not change the display on the hour meter it still reads 0000 and the e light for the gas is just flashing any ideas, I hate to take back to the dealer they are 6 hours away.
  • Mandalay Parr wrote:
    Some hour meters run off of 12vdc and others off of 120vac.
    Do a google search on the brand you have then hook up a wire accordingly.
    Others will be willing to help if you need it.
    I just checked mine. It is Quartz brand and runs off of 120vac.
    I assume you have a Onan Diesel and you are talking about the hourmeter built in to the Onan. IF you have a remote hourmeter on your model, it will be 12 volt not 120 volt. A LOT of motorhomes have 2 hourmeters. ON the Onan and then the remote meter. If the OP has a remote meter, it will be 12 volt and runs off the 12 volt indicator light at the remote panel. Doug
  • DrewE's avatar
    DrewE
    Explorer III
    How the hour meter is worked very much depends on the generator model. The Onan RV generators (well, the 4KY models at least) use a 12V DC line from the generator's control board to power the hour meter and the "running" pilot light on the remote panel. It's a standard 12V hour meter/counter.
  • happycamper002 wrote:
    Are you asking me or telling me?
    I'm asking. But also pointing out how others use product names in their posts.
    I have a non-battery type which (because of forum restriction) cannot endorse.
    Just tell us the name/type you have. That's not endorsing the product.
    If that was the case, no one could comment on the make/model of their RV or any other equipment they use. ;)
    Look at how many of us tell others how good Eternabond and Dicor is for roof repairs.
  • Other brands have 1.5 volts battery/ies similar to calculators or weather stations etc. They still require the pulse signal "wrapped around wire" at the spark plug.
    Look under online flea market---the selection is enormous you'd have a hard time deciding which one to buy--that is if you decide to replace yours, which I assume mounted on the dash?.
    Designed mostly for motorcycles and other engines with one to two cylinders.
    All the best.
  • Some hour meters run off of 12vdc and others off of 120vac.
    I just checked my 8kw Onan diesel remote hour meter in my dash. It is Quartz brand and runs off of 120vac according to Google.
  • For gasoline generators, the hour meters typically have a sense wire that is wrapped around a spark plug cable. Check on the generator and look for a wire that appears to be loose, maybe it's just not wrapped around the spark plug cable enough times.
    No idea how diesel generators measure time, since there's no spark plugs?
