eb145's avatar
eb145
Explorer II
Oct 26, 2015
24V battery bank with solar - pros and cons
Hmmm.... should I go with a 24V Battery bank?
I am in the planning phase of a 800 to 1,000 Watt solar system for my 5th wheel. I am thinking maybe a Morningstar TS-MPPT-60 charge controller and 4 GC2 AGM batteries. (AGM because of where I plan to put the batteries). And 4 250 Watt solar panels in a series/parallel arrangement so I don't exceed max Voc of the TS-MPPT-60 charge controller.
Some recent posts have discussed using 24V battery banks with a DC/DC converter (from Victron for example) to supply 12V from the 24V battery bank.
Here are the pros and cons that I can think of with a 24V battery bank (4 GC2s in series):
Pros of 24V vs. 12V battery bank:
- Solar controller (TS-MPPT-60) can double the power (Watts) it can output when charging a 24V battery bank vs. 12V (60Amps X 24V vs. 60Amps X 12V)
- Battery wires can be thinner due to lower current flow
- Batteries will perform more efficiently due to lower current flow
- inverter will be more efficient from 24V DC (not sure about this one)
Cons:
- need to buy and install a 24V to 12V DC/DC converter.
Any other pros and cons? Comments?
Thanks,
Ed
Having RV issues? Connect with others who have been in your shoes.24,294 PostsLatest Activity: Aug 02, 2025
