MEXICOWANDERER
Jul 25, 2016Explorer
Harbor Fright used to be a great deal. Now they are merely ho-hum.
Diagonal squishing pliers. Squeeze until the wire gives up and separates due to fatigue.
Drill. Chucks made out of mild steel. The Jacobs style were sooooooo soft steel the Chinese gave up and starting making the chucks hand tighten. Oooooooo so good for galling drills.
Battery Chargers. They are all SMART chargers except their roll around shop charger which is a Solar brand and found cheaper elsewhere.
MARINE Heat Shrink Tubing Kit. This is a 3 to 1 shrink ratio kit with adhesive liner and it works excellently. Same for their BLACK CABLE TIES
Electrical Terminals. You must be joking. Off center ring terminal holes. Foil thick conductor. Plastic not vinyl insulation.
Hydraulics. A breeze to buy. As you are carrying the box out, the hydraulic oil leaks and before you know it you've slid/arrived at the trunk of your car.
Make wise choices of what you buy
