BobsYourUncle
Apr 12, 2021Nomad
Check to be sure the fitting is adequately tightened onto the bottle.
I had one once that wasn't tight enough to actuate the gas flow. I checked to be sure it was clean and free of any dirt, then snugged it up good and it worked fine.
They are designed to cut the flow if it does not have a good firm fit.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
