NRALIFR
Apr 13, 2021Explorer
I had a 30 lb cylinder recently that had the same problem. Wasn’t the auto-switch regulator, wasn’t the pigtail causing the problem. I ended up having to have the tank valve replaced. The LP dealer tech confirmed the problem with his equipment. I don’t know what can go wrong with the OPD valve to make it fail that way, but it did.
Fortunately, the valves aren’t expensive, and it counts as a tank recertification as long as they mark the tank accordingly.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
