mlts22
Jan 20, 2014Explorer II
Jacks are great going down, but when going up, it is only a relatively puny spring lifting them up.
Dropping jacks onto blocks is probably a habit for other terrain. I know that I'd be throwing blocks under jacks, or at least some type of object to spread the load out since jacks tend to have a small surface area. On asphalt, this might leave marks. I'm used to camping on sugar sand, so if I dropped jacks without using boards or blocks, the jacks would just burrow into the ground, and would require some digging to get them lifted back, as well as some TLC to get the abrasive sand out of the mechanism.
If blocks are too heavy, there was a review in Motorhome magazine about boards with ropes attached, so one can just chuck the boards underneath the jacks, drop them, then just grab the ropes after lifting the jacks up when it is time to leave. Quite a back-saver.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
