Lynnmor
Mar 07, 2021Explorer II
FontanaHorseman wrote:
Thx for replys!
Bled relief valve (always do that).
Did not move any valves since do air blow out not antifreeze.
Tried the reset buttons....nothing hppened.
Outside shower had both valves open but no head on it ... and after shutting those off she fired up on both electric AND dsi!
What does that do to lock down the HW heater???
Thx, FH
Do not bleed the relief valve, you want the air cushion for expansion.
You must have moved valves to get the lukewarm condition.
The reset buttons may have helped, it works now.
If the shower valves were open, then water would be gushing out unless there is a shutoff still functioning.
There is no connection between water valves and water pressure and the ability to make heat. If the water heater isn't full, it will be damaged if turned on.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
