tjohnsen
Mar 14, 2017Explorer
Suburban water heater problem
I have a 2005 Keystone Raptor 299MP with a Suburban SW12DE water heater. It has run well on propane until recently. I run it exclusively on LP because it hasn't wanted to work on electric, but we boon dock a lot anyway so I didn't worry about the electric element issue.
About two months ago we had family over and they stayed in the trailer. We could not get the water hot. Weird thing is that the LP is cooking good and hard under the heater like it is supposed to. Good blue, strong flame with the audible rumble I've always heard when the water is heating.
I looked for answers and this is what I've done:
- Made sure the valves were closed at the exterior shower
- Made sure the tank is full. I get strong water flow out of all hot faucets in the trailer. Water gets almost luke warm so I know water is coming out of heater
- I heard it could be the bypass valve. I've never used the bypass valve because it rarely gets below freezing here. However, I did find one valve (couldn't find two) coming off the cold side of the bottom of the back of the heater. I turned the valve and it feels good. I've felt failed gate/ball valves before where there is not resistance when turning the valve. This one has a good amount of resistance to it as though it is working fine.
I replaced the anode and flushed the tank two years ago, perhaps I need to do that again.
Can anyone point me in a direction to start in fixing this thing?
Thank you!
Thank you!
