pianotuna
Jun 06, 2015Nomad III
Hi,
If you do add a transfer switch I'd get one rated at double the possible load. I.e. 60 amp rating. That is what Magnum does for their inverters.
Some air conditioners can be run on a 15 amp circuit. Try yours out and measure the voltage drop. If it stays above 107 volts it will be fine.
