Terry 25 wrote:
Just bought a Puma 25BHFQ. One A/C and a 30 amp camper in every way but the plug and cord are 50 amp. Must I always use an adapter or can I plug into 50 amp if available? Thanks. The camper is on a permanent site with a 30 amp plug. I'd like to eliminate the adapter by installing a 50 amp plug.
You didn't say what year the new to you camper was or if it was used and brand new. I'll add a few comments to attempt to help the cause.
I have seen new campers (2019 and newer, at least) wired and corded with a 50 amp shoreline cord and 4-prong plug with only one roof AC unit.
I "think, (not knowing for sure) this is a sales tactic to lower the overall selling cost. The power converter has a 50 amp 2 pole main pole breaker to split the camper loads into two 120 VAC 50 amp sections. This setup is a 50 amp camper, and they created power converter space and pre-wired the bedroom for a 2nd AC unit but did not install the 2nd AC unit. Thus, they can charge more for a 2nd AC unit as an adder but list the camper cheaper as standard. This camper has normal loads on both sides of the main 50 amp 2 pole breaker, not just the 2nd AC option.
A picture of the power converter breakers will likely solve all this mystery.
The adapter, the 30 amp male plug to a 50 amp receptacle, heads up, they sell two versions of this adapter, and pending your camper needs, it may or may not work for you.
Version 1: The adapter has a jumper molded into the 50 amp receptacle end to tie both hot legs together. This allows the 30 amp plug / 30 amp shore power outlet to power the entire camper with a split 50 amp 2 pole power converter breaker. You are still only limited to 30 amps of incoming power.
Version 2: The adapter "does not" have a jumper molded into the 50 amp receptacle end to tie both hot legs together. This adapter only powers up one leg of the 50 amp 2 pole power converter breaker. This means only half your camper will have power, which is the side that only got the power. The other leg is dead.
Yes, they make them like this as I bought one of the version 2's this spring. After figuring out the issue with a meter, I had to return that brand and buy a Camco one that I knew had the 2 hot wires jumper in it. Neither brand ever stated if there was a jumper on the 50 amp receptacle end. It is hit or miss, pending the brand.
Hope this helps,
John
PS Here is a pic of the camper wired for 50 amp but only one AC unit. They even included the 2nd AC unit breaker, it just does not have the 2nd AC. You can see, there is split power on both sides of the 50 amp main breaker that needs power from a 30 amp cord.
EDIT: 5/17/23. added extra wording to describe the 30M to 50F adapter.
