RoyB
Jun 19, 2016Explorer III
I would go back on the other end of the cable and use my hand real tight around the cable and keep workiing the outer part towards the other end...
You will gain alot outter shell covering doing this.
Then the cable should push into the head pretty far now. Then you use some rubber glue or whatever it is called and re-glue all around the two sections...
If it wasn't so large I would use some adhesive heat shrink around both sections and heat it up to shrink both ends together...
Or you can go to ETRAILER.COM and but a new 30A cable with a new molded head on it...
Or you can pick up a new 30A plug and cut this end off and install the new head onto this cable which will use crimp-on or solder-up connections...
I like the idea of just getting a new one from ETRAILER.COM
Roy Ken
Roy Ken
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
