NinerBikes
Jan 25, 2016Explorer
smkettner wrote:
Also depends on the wire insulation rating. IIRC Typical romex is 60° while THNN is 90° or 105° and can carry a bit more.
The temp rating of THNN being 90 or 105 is you wasting electrical energy that you are paying for and going up in watts and resistance, raising the temperature of the wire when run at continuous high electrical loads. If the wire is making heat, on a regular basis, go down a gauge in wire, or up a size in thickness of the wire, to get rid of the heat losses.
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
