time2roll
Sep 29, 2015Nomad
Generally this is a dedicated circuit so I have to think it is a motor issue drawing too much power. Trace and inspect the wire after the switch for a short but I doubt that is the issue. Are you sure it is supposed to be a 30 amp fuse?
It is common for a motor to draw more power with low voltage so possibly a bad connection or the OEM wire is marginal. I assume the motor seems to run normal and does not sound like it is straining.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
