dougrainer
Sep 29, 2015Nomad
1. Install a 30 amp auto reset Circuit breaker. CHEAPER than replacing fuses.
2. I(F you are positive that the ONLY item on that 30 amp fuse is the landing gear, then the motor is probably defective. IF you have other 12 volt items on that fuse then the accumulated amp draw may be blowing the 30 amp fuse. Doug
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
