azrving
Sep 29, 2015Explorer
dougrainer wrote:
1. Install a 30 amp auto reset Circuit breaker. CHEAPER than replacing fuses.
2. I(F you are positive that the ONLY item on that 30 amp fuse is the landing gear, then the motor is probably defective. IF you have other 12 volt items on that fuse then the accumulated amp draw may be blowing the 30 amp fuse. Doug
The only problem with auto reset circuit breakers is that some designs will weld the tips and take out the harness. I'm speaking of the clicker style that is basically a metal arm that heats up and pops open. When a fault occurs and they sit and cycle over and over and can end up welding the tips. Just mentioning it. The only breaker I would use would be a manual reset. If it pops maybe it's a one time thing, if it does it again find the problem.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
