Old-Biscuit
Sep 29, 2015Explorer III
You stated worked just fine after installing new set of batteries ....then not working.
Have you checked the battery voltage with a 'real' meter?
Not that phony monitor that will always show full charge anytime you are plugged into shore power.
IS your converter keeping new batteries charged??
Converter DC output should be 13.2V DC (with batteries not connected).
When you installed those new batteries did you by chance hook up backwards and blow the 'reverse polarity' fuses on converter (30A or higher.....can be on front or back)??
Batteries just getting a charge when connected to truck and now low voltage?
Use voltmeter and check batteries.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
