Ronjames's avatar
Ronjames
30 AMP shore power tripping
Our 2004 Puma is on a permanent site at the campground and we stay plugged in to the 30 Amp pedestal on the site. Never a problem for the year we've done this. Yesterday, we plugged in a electric skillet to the outside receptacle on the camper. Since we had the AC running and everything but the microwave I was just about to say "we should probably run this skillet straight from the 20amp on the pedestal." I never even got the words out and then POOF! Everything shut down. I checked the breakers and fuses on the trailer's power converter, but they did not trip. I checked the pedestal 30amp breaker and it was tripped. With everything turned off and unlplugged in the camper, I reset the breaker. but it would not reset. it was an immediate trip. I swapped my shore power cable to the adjacent site to see if maybe the breaker was bad on my site's pedestal. But nope, it tripped immediately. All breakers and fuses in my Parallax Power 7300 checked out good. SO...could it be that I smoked something in my Parallax 7300? I would have thought if that was the case I would have tripped the camper's breakers. Any helpful thoughts would be appreciated.
  • if you have a transfer switch it is usually between the RV main breaker and the campground breaker. If shorted out it would cause this.
  • Shut off all off for breakers. Does it still trip?
    If not Bring each circuit back until you find the culprit.
    Oh and don't forget the electric water heater.
