Chris_Bryant
Oct 31, 2015Explorer II
Heck, you want expensive, look at the Furman AR Pro- will take anything between 80 and 267 volts and put out 120 vac +-4%. 97% efficiency...
$4,000. 50 lbs, rack mount. I've used the 2400 watt model a bunch for pro audio, never used the 3600 watt model though.
The AR-PRO uses a design based on a 25-tap toroidal autoformer. The toroidal design assures minimal leakage of stray magnetic fields and a highly efficient, compact package. The AR-PRO's circuitry monitors the incoming line voltage with each cycle. If a voltage change requires that a different tap be selected, the new tap is electronically switched in precisely at the zero-crossing, to avoid distorting the AC waveform. If necessary, the AR-PRO can switch taps as often as once each cycle.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
