greenrvgreen
Nov 01, 2015Explorer
Tuna--
The reason I specified the Iota DLS is that it will provide continuous current at its rating virtually indefinitely. It is a POWER SUPPLY with (mediocre) multi-stage charging capabilities. Therefore it is perfect for this task.
With a $25 pendant you can link two similar DLS units and double your amperage. If you are on a 30A shore connection that is showing 90 volts (normally unusable), with line losses in the 30% range you will have perfect power from your inverter, perfectly protected. No autoformer or variac can do this.
If your inverter is capable of providing 30 amps, then at maximum draw your battery depletion rate would be ~8A (AC). Say you have a 300ah draw limit from you bank, that would be three hours.
But how often do we pull 22 amps? And how many people have an inverter capable of providing that? The realistic scenario is that your draw from inverter will never exceed your charge from the Iota, and you can continue for the entirety of your stay at the campground. I've done it and it works amazingly well!
Even better, you can add another, external charger powered by a gennie. During periods of heavy inverting, ANY charge voltage will contribute 100% of its amps to the battery.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
