DutchmenSport
Aug 13, 2016Explorer
Turn everything off that is not necessary. Then turn on both air-conditioners. If they run, then your answer is "yes". If the breaker pops, either the one inside your camper or the one at the power pedistal, then the answer is no. The worth that will happen when you turn both on is, the breaker will pop. Nothing hurt. Turn one air conditioner back off, and reset the breaker. Then you'll know.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
