You_can_t_take_
Aug 13, 2016Explorer
One additional hint. To insure that both units do not start at the same time (which draws extra power) turn the thermostat on the primary unit down really low so it is in continuous run mode. Then use the second unit to control the actual indoor temperature.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
