joebedford
Aug 14, 2016Nomad III
Couple of things:
1) my 5th wheel is wired for 50A but does not have an EMS.
2) turn the converter off before you attempt to run two ACs - it can draw a lot.
3) if your THERMOSTAT is like mine, it will not start both ACs at the same time - there is a time lag of about 30 seconds. No need to set different temperatures.
4) right now my rig is on a weak 15A circuit which will not run even one AC. In a couple of days I'm going to move my rig to where I can plug into 30A. I'll try the two AC test then and let you know.
5) I guess this is more than a couple of things.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
