toedtoes
Apr 17, 2023Explorer III
katysdad wrote:I'll bet the assembly line workers ran out of 30 amp cords and added a 50 amp instead because they had it on hand. The question is did they only connect one of the two hot wires (this would be good as it's 120v 30 amp). Or did they do some kind of bonehead move and twist the two hot leads together under one screw creating 240v (This would be bad).
This would not put 240V into trailer. It would be a direct short at the pedestel and immediatly trip the pedestel breaker even if not connected to trailer input.
I also think it's unlikely this happened IF the 50amp cord is detachable as the OP suggests. If that were the case, then the connection to the RV would have remained 30amp.
If the cord is detachable, then that suggests that both the port on the RV AND the cord were switched to 50amps.
