dougrainer
Apr 17, 2023Nomad
The OP stated the shore cord was connected at walk thru. SO, if so, and there WAS a miswire, then how did the 120 appliances operate during the walk thru?????????????????????????? The OP needs to respond if the dealer did a good walk thru and the OP SAW that the TV and Microwave and Roof AC operated. Me thinks that he has a BAD power converter and THAT caused the battery system to go dead except for solar and his 120 appliances still operate. On a 30 amp trailer which has a outside input and you plug in the shore cord a 50 amp cord will NOT connect to that 30 amp wall plug on the trailer. Different size and connections. Doug
