dougrainer
Apr 18, 2023Nomad
1. IF 50 amp trailer it WILL state on outside label where shore cord connects.
2. It IS possible that Keystone installed the wrong 30/50 label on the outside
3. At the 120 breaker box. ALL the OP has to do is go to the trailer and look at Breaker box. IF HE HAS A 50 AMP TRAILER THERE WILL BE 2-50 AMP BREAKERS.
4. op, YOUR ROOF AC RUNS OFF 120 VOLTS. The wall tstat controls are 12 volt.
5. A Residential refer will look exactly like a Home refer(because they ARE the same). RV refers will be built into the cabinet, OFF the floor. Residential's will be on the floor of the RV inside the cabinet. If residential will have a name brand, that you will recognize. Residential's are 120 volts only.
6. Now, you want a 2nd AC. UNLESS your RV has 50 amp, you CANNOT install a 2nd AC. 30 amp service will not run 2 AC units.
7. Online Video from CW for the 2023 Mallard M-32. Shows RV refer
states 50 amp service. Doug
