stevenal
Apr 20, 2023Nomad III
Adapter
Here is an adapter as described. Internally, the ground, neutral, and one of the legs connect straight through. The remaining leg remains unconnected. Note that it carries no UL mark. This same sort of adaptation might simply be wired into the RV, and would likely be in violation of RVIA standards. If so, the 12000 W expected from the 50 A service is only 3600.
As others have indicated, find your main breaker. It will be a single pole 30 or a double pole 50.
