CA_Traveler
Apr 20, 2023Explorer III
Any Jayco electrical engineer should know that a 50A 120/240V circuit can supply 240V or 2x 120V or combinations of the 2 voltages and 3 A/Cs is common on larger rigs. This is the same circuit as every house except houses are 100A or larger.
A friend has a high end RV with 4 ACs that will all run on a 50A pedestal. But if not due to total loads the 20KW gen will kick in...:B
