Grit_dog
Apr 20, 2023Trailblazer
toedtoes wrote:ODG255 wrote:
I am going to try and get to the dealer today and see if I can take pictures of the breakers. I’m sure they have been dragging their feet and haven’t looked into it at all.
This is turning into quite the disaster. My gut tells me I should get rid of the trailer but I doubt they will do that without a fight. Going to do some research into consumer law and try to be prepared
Trust your gut.
If you take this trailer to Arizona and try to power two AC units, you are going to burned. It doesn't matter what they do, you cannot trust the wiring on this rig. It's dangerous.
In your expert electrician opinion formulated by cryptic descriptions from the OP that still leave most of the necessary info to one’s imagination?
I really feel for the OP but until he can at least provide enough info to identify what supply setup he has, what ACTUALLY doesn’t work (because he’s only said the battery went dead afaik) and whether it’s pre wired for a second AC, most of this is pure speculation on our part.
While anything is possible it’s highly unlikely that the camper is “wired all wrong” which is what’s being suggested by many.
And it is of less than zero use to keep discussing how many air conditioners people can run off their boondocking on steroids setups.
