brulaz
Aug 12, 2015Explorer
It's great that these new controllers tell you when there's a problem like that. My old P2 never did, and I only discovered a similar problem by checking the brake drum temperatures after a hard stop.
My problem was caused by a broken brake wire right at the drum. Total PITA to fix.
Also. the Ford brake controller will only output low brake controller voltages when the truck is not moving. It varies the voltage with speed and other conditions.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
