bedpan
Aug 12, 2015Explorer II
Tried to post earlier.. Koa wifi was less then ideal.
Anyways played with the 7 pin connector, checked fuses and battery on trailer. No luck...
I then followed the wire into the trailer. Was a bear to open up the bench seat. Found hiding behind the fresh water tank the blue wire marreted with 2 other wires. Touched the marrett and a wire fell out.
Wires were all striped different lengths and not twisted together at all. Poor workmanship. Twisted and marreted and life is good again.
Second wiring issue I have had. First was a broken wire on the 1/3 full fresh water sensor. Also noticed when I was crawling underneath the front stone guard incoming loose. Some screws missing and others gone. I will leave that for the dealer to fix when I get back.
Still love the trailer just a few issues had/have to be sorted out.
Thanks for all the help....
Mike
Mike
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
