bedpan's avatar
bedpan
3000 Miles from home - brake issues...... THoughts?
Hey folks.. I am about halfway through a 7000 Mile trip (Toronto to Revelstoke, Seattle and back through the USA). Today driving east from Seattle along I90 I started having some brake issues.
Some quick specs
2013 F150 Ecoboost FX4 SCREW bought used 5 months or so ago
Towing 2015 18BH Starcraft bought brand new for this trip
Problem started as truck reporting the trailer disconnect then reconnected again quickly. It did this a few times. I stopped and re-seated the 7-pin connecter. Seemed ok for a bit then started again.
Stopped again reseated, checked lights, ground connections and wiggled wires. Again after a short period it started doing it again. I ignored it at this point. Lights were working so I plowed on to our stop for the night. After a bit the disconnects got longer before it would reconnect. The last 20 miles or so it stopped connecting at all.
Manually applying brakes via the integrated brake controller does nothing.
So here I am at the Ellensburg WA KOA. Tomorrow morning I once I have some day light I plan on poking around see what I can figure out. This is my first trailer with brakes so its a new cup of tea for me. Thought I would start first by begging a fellow camper to plug into thier trailer to see if it works and the other way around. I figure this will at least tell me if its a truck problem or a trailer.
Any other troubleshooting techniques for brakes?
Many thanks in advance!
Mike
Just adding.. This was done on my phone so sorry for bad english spelling grammer and other things that people don't like to see ;-)
  • If you have a volt meter, set it for DC volts, and measure between pins 1&2 on the seven way connector on your truck. Make sure the key is in the run position, and have someone manually apply the trailer brake while you watch the voltage. If there is no voltage, the problem is with the truck. If there is voltage, it's time to trace the wires and find out where the open circuit is. Here's an image of the 7-way connector so you can get a feel for the pin configuration:
    Jim
  • Your grammar, sentence structure, syntax, punctuation etcetera, while perhaps not perfect for a University level English course, is better than a lot seen here. :B
  • First thought---get some fine sandpaper or emery cloth and clean all the pins on the connector.
    Then start looking for loose wires, or a total wiring harness bad connection.
Having RV issues? Connect with others who have been in your shoes.24,305 PostsLatest Activity: Aug 28, 2025
