Almot
Jun 08, 2014Explorer III
Don is right, some TV will only work on pure sin.
There is - usually - no benefit in getting bigger inverter than needed. A good TV of that size will draw less than 50W, though even a bad one should still draw waay less than 300. Check TV specs.
If there is no difference in idle draw of 300 and 500W inverter, or noise (i.e. both have no fans or installed far away where it doesn't bother you), and both are pure sin, - get the one that is cheaper.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
