BFL13's avatar
BFL13
Explorer II
Mar 15, 2021
TV on Inverter 2000w VS 300w Draws
Tested for this with each inverter clamped to battery bank in turn, 32" TV, and Trimetric for volts and amps.
300w- off: 12.6v, 00.2a
on: 12.6v, 00.5a
TV on: 12.5v , 9.2a (climbing slowly with "inverter creep")
2000w- off: 12.6v, 00.2a
on: 12.6v, 00.9a
TV on: 12.5v, 9.3a (climbing slowly with "inverter creep")
300w in 12v socket in "TV panel" alarmed off- (wires too thin)
Note in previous threads about this, it came out that the loaded amps depends on the load's place on the efficiency curve of each inverter and you can't just add the load to the standby draw.
Each inverter has its own 12v wire gauges. I did not test for using fat wires with the 300w, just the ones it came with.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
